查看: 8660|回复: 7
[原创] 【高校争霸赛】基于LPC824lite沛喆气压计FBM320 通过写的IIC读取
  • 签到天数: 12 天
    发表于 2016-12-11 23:21:45 | 显示全部楼层 |阅读模式
    一.团队名称
    学校:汕头大学
    队员:2
    二.项目流程
    背景:由于师弟的有个毕业设计题目为:大棚温湿度保持系统。故把主控芯片选为NXP,由于把温湿度传感器给师弟了(并且我现在不在学校),现在手里只有显示温度和气压的压力传感器和LPC824lite故现在我用气压传感器和LPC824lite先把项目做完,先提交。题目改为:基于NXP的大棚温湿度和压力保持系统。
    至于FBM320的datasheet,大家就去看我上一篇帖子。
    把气压计读出来再写程序,然后根据气压大小和温度高低来判断是启用扇风还是加热操作。直接上FBM320由原始值最后转换为气压的算法了,(完整代码在底下)输入温度和气压原始值:
    1. if(((Formula_Select & 0xF0) == 0x10) || ((Formula_Select & 0x0F) == 0x01))
    2.         {
    3.                 C0 = R[0] >> 4;
    4.                 C1 = ((R[1] & 0xFF00) >> 5) | (R[2] & 7);
    5.                 C2 = ((R[1] & 0xFF) << 1) | (R[4] & 1);
    6.                 C3 = R[2] >> 3;
    7.                 C4 = ((uint32_t)R[3] << 2) | (R[0] & 3);
    8.                 C5 = R[4] >> 1;
    9.                 C6 = R[5] >> 3;
    10.                 C7 = ((uint32_t)R[6] << 3) | (R[5] & 7);
    11.                 C8 = R[7] >> 3;
    12.                 C9 = R[8] >> 2;
    13.                 C10 = ((R[9] & 0xFF00) >> 6) | (R[8] & 3);
    14.                 C11 = R[9] & 0xFF;
    15.                 C12 = ((R[0] & 0x0C) << 1) | (R[7] & 7);
    16.         }
    17.         else
    18.         {
    19.                 C0 = R[0] >> 4;
    20.                 C1 = ((R[1] & 0xFF00) >> 5) | (R[2] & 7);
    21.                 C2 = ((R[1] & 0xFF) << 1) | (R[4] & 1);
    22.                 C3 = R[2] >> 3;
    23.                 C4 = ((uint32_t)R[3] << 1) | (R[5] & 1);
    24.                 C5 = R[4] >> 1;
    25.                 C6 = R[5] >> 3;
    26.                 C7 = ((uint32_t)R[6] << 2) | ((R[0] >> 2) & 3);
    27.                 C8 = R[7] >> 3;
    28.                 C9 = R[8] >> 2;
    29.                 C10 = ((R[9] & 0xFF00) >> 6) | (R[8] & 3);
    30.                 C11 = R[9] & 0xFF;
    31.                 C12 = ((R[5] & 6) << 2) | (R[7] & 7);
    32.         }
    33.         C0_I = C0;
    34.         C1_I = C1;
    35.         C2_I = C2;
    36.         C3_I = C3;
    37.         C4_I = C4;
    38.         C5_I = C5;
    39.         C6_I = C6;
    40.         C7_I = C7;
    41.         C8_I = C8;
    42.         C9_I = C9;
    43.         C10_I = C10;
    44.         C11_I = C11;
    45.         C12_I = C12;
    46. }
    47. void Calculate(int32_t UP, int32_t UT)                //Calculate Real Pressure & Temperautre
    48. {
    49.         int8_t C12=0;
    50.         int16_t C0=0, C2=0, C3=0, C6=0, C8=0, C9=0, C10=0, C11=0;
    51.         int32_t C1=0, C4=0, C5=0, C7=0;
    52.         int32_t RP=0, RT=0;
    53.         int32_t DT, DT2, X01, X02, X03, X11, X12, X13, X21, X22, X23, X24, X25, X26, X31, X32, CF, PP1, PP2, PP3, PP4;
    54.         C0 = C0_I;
    55.         C1 = C1_I;
    56.         C2 = C2_I;
    57.         C3 = C3_I;
    58.         C4 = C4_I;
    59.         C5 = C5_I;
    60.         C6 = C6_I;
    61.         C7 = C7_I;
    62.         C8 = C8_I;
    63.         C9 = C9_I;
    64.         C10 = C10_I;
    65.         C11 = C11_I;
    66.         C12 = C12_I;
    67.         if(((Formula_Select & 0xF0) == 0x10) || ((Formula_Select & 0x0F) == 0x01))                        //For FBM320-02
    68.         {
    69.                 DT        =        ((UT - 8388608) >> 4) + (C0 << 4);
    70.                 X01        =        (C1 + 4459) * DT >> 1;
    71.                 X02        =        ((((C2 - 256) * DT) >> 14) * DT) >> 4;
    72.                 X03        =        (((((C3 * DT) >> 18) * DT) >> 18) * DT);
    73.                 RT        =        ((2500 << 15) - X01 - X02 - X03) >> 15;
    74.
    75.                 DT2        =        (X01 + X02 + X03) >> 12;
    76.
    77.                 X11        =        ((C5 - 4443) * DT2);
    78.                 X12        =        (((C6 * DT2) >> 16) * DT2) >> 2;
    79.                 X13        =        ((X11 + X12) >> 10) + ((C4 + 120586) << 4);
    80.
    81.                 X21        =        ((C8 + 7180) * DT2) >> 10;
    82.                 X22        =        (((C9 * DT2) >> 17) * DT2) >> 12;
    83.                 if(X22 >= X21)
    84.                         X23        =        X22 - X21;
    85.                 else
    86.                         X23        =        X21 - X22;
    87.                 X24        =        (X23 >> 11) * (C7 + 166426);
    88.                 X25        =        ((X23 & 0x7FF) * (C7 + 166426)) >> 11;
    89.                 if((X22 - X21) < 0)
    90.                         X26        =        ((0 - X24 - X25) >> 11) + C7 + 166426;
    91.                 else
    92.                         X26        =        ((X24 + X25) >> 11) + C7 + 166426;
    93.
    94.                 PP1        =        ((UP - 8388608) - X13) >> 3;
    95.                 PP2        =        (X26 >> 11) * PP1;
    96.                 PP3        =        ((X26 & 0x7FF) * PP1) >> 11;
    97.                 PP4        =        (PP2 + PP3) >> 10;
    98.
    99.                 CF        =        (2097152 + C12 * DT2) >> 3;
    100.                 X31        =        (((CF * C10) >> 17) * PP4) >> 2;
    101.                 X32        =        (((((CF * C11) >> 15) * PP4) >> 18) * PP4);
    102.                 RP        =        ((X31 + X32) >> 15) + PP4 + 99880;
    103.         }
    104.         else
    105.         {
    106.                 DT        =        ((UT - 8388608) >> 4) + (C0 << 4);
    107.                 X01        =        (C1 + 4418) * DT >> 1;
    108.                 X02        =        ((((C2 - 256) * DT) >> 14) * DT) >> 4;
    109.                 X03        =        (((((C3 * DT) >> 18) * DT) >> 18) * DT);
    110.                 RT = ((2500 << 15) - X01 - X02 - X03) >> 15;
    111.
    112.                 DT2        =        (X01 + X02 + X03) >>12;
    113.
    114.                 X11        =        (C5 * DT2);
    115.                 X12        =        (((C6 * DT2) >> 16) * DT2) >> 2;
    116.                 X13        =        ((X11 + X12) >> 10) + ((C4 + 211288) << 4);
    117.
    118.                 X21        =        ((C8 + 7209) * DT2) >> 10;
    119.                 X22        =        (((C9 * DT2) >> 17) * DT2) >> 12;
    120.                 if(X22 >= X21)
    121.                         X23        =        X22 - X21;
    122.                 else
    123.                         X23        =        X21 - X22;
    124.                 X24        =        (X23 >> 11) * (C7 + 285594);
    125.                 X25        =        ((X23 & 0x7FF) * (C7 + 285594)) >> 11;
    126.                 if((X22 - X21) < 0)
    127.                         X26        =        ((0 - X24 - X25) >> 11) + C7 + 285594;
    128.                 else
    129.                         X26        =        ((X24 + X25) >> 11) + C7 + 285594;
    130.                 PP1        =        ((UP - 8388608) - X13) >> 3;
    131.                 PP2        =        (X26 >> 11) * PP1;
    132.                 PP3        =        ((X26 & 0x7FF) * PP1) >> 11;
    133.                 PP4        =        (PP2 + PP3) >> 10;
    134.
    135.                 CF        =        (2097152 + C12 * DT2) >> 3;
    136.                 X31        =        (((CF * C10) >> 17) * PP4) >> 2;
    137.                 X32        =        (((((CF * C11) >> 15) * PP4) >> 18) * PP4);
    138.                 RP = ((X31 + X32) >> 15) + PP4 + 99880;
    139.         }
    140.         RP_I = RP;
    141.         RT_I = RT;
    142. }
    然后就是上图了,测得的室内气压和温度,分别为
    气压为:100972
    温度为:26.31
    附一:
    下面把IIC程序发出来:
    1. #include "IIC.h"
    2. //Ç°ÃæµÄIICºê¶¨Òå
    3. #define SDA_High                 Chip_GPIO_PinSetState(LPC_GPIO_PORT, 0, 12, true)
    4. #define SDA_Low                  Chip_GPIO_PinSetState(LPC_GPIO_PORT, 0, 12, false)
    5. #define SCL_High                 Chip_GPIO_PinSetState(LPC_GPIO_PORT, 0, 13, true)
    6. #define SCL_Low                  Chip_GPIO_PinSetState(LPC_GPIO_PORT, 0, 13, false)
    7. #define SDA_OUT                  Chip_GPIO_PinSetDIR(LPC_GPIO_PORT, 0, 12, 1)
    8. #define SDA_IN                   Chip_GPIO_PinSetDIR(LPC_GPIO_PORT, 0, 12, 0)
    9. #define SDA_State                 Chip_GPIO_PinGetState(LPC_GPIO_PORT, 0, 12)
    10. //¶¨ÒåÆ÷¼þµØÖ·
    11. #define I2C_MMA8451_ADR  0X1C
    12. #define I2C_MPU3050_ADR  0x68
    13. //¶¨ÒåһЩÒý½Å
    14. void IIC_init(void)
    15. {
    16.           /*SDA*/
    17.                 Chip_GPIO_PinSetDIR(LPC_GPIO_PORT, 0, 12, 1);//set PIO12 output
    18.           SDA_High;   //set PIO12 high logic
    19.           /*SCL*/
    20.           Chip_GPIO_PinSetDIR(LPC_GPIO_PORT, 0, 13, 1);//set PIO13 output
    21.           SCL_High;   //set PIO13 high logic
    22.           Board_UARTPutSTR("IIC initialize is OK!\r\n");
    23. //          MMA8451_Init();
    24. //          Board_UARTPutSTR("MMA8451 initialize is OK!\r\n");
    25. //          MPU3050_Init();
    26.
    27.                 Board_UARTPutSTR("IIC initialize is OK!\r\n");
    28. }
    29. /*Delay for 15 usÑÓʱ*/
    30. void IIC_Delay(void)
    31. {
    32.           uint8_t t=15;
    33.                 while( t-- );
    34. }
    35. /*The start signal of IIC BUS*/
    36. void IIC_Start(void)
    37. {
    38.           SDA_OUT;
    39.
    40.           IIC_Delay();
    41.                 /*SDA=1*/SDA_High;
    42.           /*SCL=1*/SCL_High;
    43.           IIC_Delay();
    44.           /*SDA=0*/SDA_Low;
    45.                 IIC_Delay();
    46.           /*SCL=0*/SCL_Low;
    47.                 IIC_Delay();
    48. }
    49. /*The stop signal of IIC BUS*/
    50. void IIC_Stop(void)
    51. {
    52.                 SDA_Low;
    53.                 SCL_Low;
    54.                 IIC_Delay();
    55.           SCL_High;
    56.           IIC_Delay();
    57.           SDA_High;
    58.     IIC_Delay();
    59.     SCL_Low;
    60. }
    61. /*The respons signal of IIC BUS*/
    62. void IIC_Ack(void)
    63. {
    64.     SCL_Low;
    65.           IIC_Delay();
    66.           SDA_Low;
    67.           IIC_Delay();
    68.           SCL_High;
    69.           IIC_Delay();
    70.           SCL_Low;
    71.           IIC_Delay();
    72. }
    73. /*The norespons signal of IIC BUS*/
    74. void IIC_NoAck(void)
    75. {
    76.
    77.           SCL_Low;
    78.           IIC_Delay();
    79.           SDA_High;
    80.                 IIC_Delay();
    81.           SCL_High;
    82.           IIC_Delay();
    83.           SCL_Low;
    84.                 IIC_Delay();
    85. }
    86. /*Send One Byte by IIC BUS*/
    87. void IIC_SendByte(uint8_t data)
    88. {
    89.
    90.                 uint8_t i=8;
    91.                 while(i--)
    92.                 {
    93.                         SCL_Low;
    94.                         if(data&0x80)
    95.       SDA_High;
    96.                         else
    97.       SDA_Low;
    98.                         data<<=1;
    99.                         IIC_Delay();
    100.                         SCL_High;
    101.                         IIC_Delay();
    102.                 }
    103.                 SCL_Low;
    104.                 IIC_Delay();
    105.                 SDA_High;
    106.                 IIC_Delay();
    107.
    108.                 SCL_High;
    109.                 IIC_Delay();
    110.
    111.                 SCL_Low;
    112. }
    113. /*Read One Byte by IIC BUS*/
    114. uint8_t I2C_ReceiveByte(void)
    115. {
    116.   uint8_t i=8;
    117.   uint8_t ReceiveByte=0;
    118.   SDA_High;
    119.         SDA_IN;
    120.   while(i--)
    121.   {
    122.     ReceiveByte<<=1;
    123.                 SCL_Low;
    124.     IIC_Delay();
    125.                 SCL_High;
    126.                 IIC_Delay();
    127.
    128.     if(SDA_State)
    129.     {
    130.       ReceiveByte|=0x01;
    131.     }
    132.   }
    133.   SDA_OUT;
    134.   SCL_Low;
    135.   return ReceiveByte;
    136. }
    137. /*
    138. * I2C_WriteReg
    139. * дI2CÉ豸¼Ä´æÆ÷
    140. */
    141. void I2C_Write(uint8_t dev_addr,uint8_t reg_addr , uint8_t data)
    142. {
    143.   IIC_Start();
    144.   IIC_SendByte(dev_addr<<1);
    145.   IIC_SendByte(reg_addr );
    146.   IIC_SendByte(data);
    147.   IIC_Stop();
    148. }
    149. //¶ÁÒ»¸öbufµÄÊý¾Ý
    150. uint8_t I2C_Read(uint8_t dev_addr,uint8_t reg_addr)
    151. {
    152.   uint8_t data;
    153.   IIC_Start();
    154.   IIC_SendByte( dev_addr<<1);
    155.   IIC_SendByte( reg_addr );
    156.   IIC_Start();
    157.   IIC_SendByte((dev_addr<<1)+1);
    158.   data= I2C_ReceiveByte();
    159.   IIC_NoAck();
    160.   IIC_Stop();
    161.   return data;
    162. }
    163. uint8_t I2C_Read_Buf(uint8_t sla_address, uint8_t sub_address,uint8_t        *buf,uint8_t len)
    164. {        int i = 0;
    165.   uint8_t data;
    166.   IIC_Start();
    167.   IIC_SendByte( sla_address<<1);
    168.   IIC_SendByte( sub_address );
    169.   IIC_Start();
    170.   IIC_SendByte((sla_address<<1)+1);
    171.
    172.
    173.         for(i=0;i<len-1;i++)
    174.         {
    175.                 buf[i] = I2C_ReceiveByte();
    176.           IIC_Ack();
    177.         }
    178.         buf[i] = I2C_ReceiveByte();
    179.
    180.   IIC_NoAck();
    181.   IIC_Stop();
    182.   return 1;
    183. }
    184. //¸ßλºÍµØÎ»ºÏ²¢
    185. int16_t I2C_ReadWord(uint8_t dev_addr,uint8_t reg_addr)
    186. {
    187.   char h,l;
    188.   IIC_Start();
    189.   IIC_SendByte( dev_addr<<1);
    190.   IIC_SendByte( reg_addr);
    191.   IIC_Start();
    192.   IIC_SendByte((dev_addr<<1)+1);
    193.   h= I2C_ReceiveByte();
    194.   IIC_Ack();
    195.   l= I2C_ReceiveByte();
    196.   IIC_NoAck();
    197.   IIC_Stop();
    198.   return (h<<8)+l;
    199. }
    200. void DelayMs(uint16_t ms)
    201. {
    202.    uint16_t i=0;
    203.    while(ms--)
    204.    {
    205.       i=5000;
    206.       while(i--) ;
    207.    }
    208. }
    附二
    下面是头文件iic.h
    1. #ifndef __IIC_H_
    2. #define __IIC_H_
    3. #include "chip.h"
    4. #include "board.h"
    5. void IIC_init(void);
    6. void IIC_Delay(void);
    7. void IIC_Start(void);
    8. void IIC_Stop(void);
    9. void IIC_Ack(void);
    10. void IIC_NoAck(void);
    11. void IIC_SendByte(uint8_t data);
    12. uint8_t I2C_ReceiveByte(void);
    13. void I2C_WriteReg(uint8_t dev_addr,uint8_t reg_addr , uint8_t data);
    14. uint8_t IIC_ReadByte(uint8_t dev_addr,uint8_t reg_addr);
    15. int16_t I2C_ReadWord(uint8_t dev_addr,uint8_t reg_addr);
    16. uint8_t I2C_Read(uint8_t dev_addr,uint8_t reg_addr);
    17. void I2C_Write(uint8_t dev_addr,uint8_t reg_addr , uint8_t data);
    18. uint8_t IIC_Read_Buf(uint8_t sla_address, uint8_t sub_address,uint8_t        *buf,uint8_t len);
    19. void I2C_ReadGryo(uint8_t dev_addr,uint8_t reg_addr,int16_t *x,int16_t *y);
    20. void DelayMs(uint16_t ms);
    21. #endif
    附三:
    1. #include <stdint.h>
    2. #include <math.h>
    3. #include <string.h>
    4. #include "FBM320.h"
    5. #include "IIC.h"
    6. int32_t UP_S=0, UT_S=0, RP_S=0, RT_S=0, OffP_S=0;
    7. int32_t UP_I=0, UT_I=0, RP_I=0, RT_I=0, OffP_I=0;
    8. float H_S=0, H_I=0;
    9. float Rpress;
    10. uint16_t C0_S, C1_S, C2_S, C3_S, C6_S, C8_S, C9_S, C10_S, C11_S, C12_S;
    11. uint32_t C4_S, C5_S, C7_S;
    12. uint16_t C0_I, C1_I, C2_I, C3_I, C6_I, C8_I, C9_I, C10_I, C11_I, C12_I;
    13. uint32_t C4_I, C5_I, C7_I;
    14. uint8_t        Formula_Select=0;
    15. #define P_CONVERSION_TIME_MS   20
    16. #define T_CONVERSION_TIME_MS   5
    17. static uint32_t lastConv=0;
    18. static uint8_t readState=0;
    19. static uint8_t conversion_Time = T_CONVERSION_TIME_MS;
    20. // Read 2 bytes from the fbm320
    21. // First byte will be from 'address'
    22. // Second byte will be from 'address'+1
    23. int fbm320ReadInt(unsigned char address)
    24. {
    25.         uint8_t        data[2];
    26. //        I2C_Read_Buf(fbm320_address,address,data,2);
    27. //        return        (int)(data[0] << 8 | data[1]);
    28.
    29.         data[0]=I2C_Read(fbm320_address,address);
    30.         return data[0];
    31.
    32. }
    33. // Read 1 bytes from the fbm320
    34. int fbm320ReadInt1(unsigned char address)
    35. {
    36.         uint8_t        data[1];
    37.         I2C_Read_Buf(fbm320_address,address,data,1);
    38.         return        (int)data[0];
    39. }
    40. // Read 3 bytes from the fbm320
    41. long        int fbm320ReadInt3(unsigned char address)
    42. {
    43.         uint8_t        data[3];
    44.         data[0]=I2C_Read(fbm320_address,0xf6);
    45.         data[1]=I2C_Read(fbm320_address,0xf7);
    46.         data[2]=I2C_Read(fbm320_address,0xf8);
    47. //        I2C_Read_Buf(fbm320_address,address,data,3);
    48.         return        (long        int)(data[0] << 16 | data[1] << 8 | data[2]);
    49. }
    50. void FBM320Initial(void)        //Initial FBM320 SPI or I2C Bus Protocol
    51. {
    52.         if(I2C_Read(fbm320_address,0x6B) == 0x42)
    53.         {
    54.         //        if((I2C_Read(fbm320_address,0xf4) & 0x40) == 0x40)
    55.                         Formula_Select |= 0x01;
    56.                 Coefficient();
    57.                 I2C_Write(fbm320_address,0xF4, 0x2E);
    58.                 DelayMs(100);
    59.                 UT_I = fbm320ReadInt3(0xf6);
    60.                 I2C_Write(fbm320_address,0xF4, 0xF4);
    61.                 DelayMs(1000);
    62.                 UP_I = fbm320ReadInt3(0xf6);
    63.                 Calculate( UP_I, UT_I);
    64.          }
    65.
    66.         I2C_Write(fbm320_address,0xF4, 0x2E);
    67.         conversion_Time = T_CONVERSION_TIME_MS;
    68.
    69.         Board_UARTPutSTR("FBM320 initialize is OK!\r\n");
    70. }
    71. void Timer_Procedure(void)
    72. {
    73.         I2C_Write(fbm320_address,0xF4, 0x2E);
    74.         DelayMs(5);
    75.         UT_I = fbm320ReadInt3(0xf6);
    76.         I2C_Write(fbm320_address,0xF4, 0xF4);
    77.         DelayMs(20);;
    78.         UP_I = fbm320ReadInt3(0xf6);
    79.         Calculate(UP_I, UT_I);
    80. }
    81. volatile        uint8_t        F_Baro_Converion = 0;
    82. void FBM320GetData(int32_t* pressure, int32_t* temperature)
    83. {
    84. // Dont reader faster than we can
    85. //    uint32_t now = time_nowMs();
    86. //    if ((now - lastConv) < conversion_Time)
    87. //    {
    88. //        return;
    89. //    }
    90. //    lastConv = now;
    91.     DelayMs(5);
    92.     if(readState == 0)
    93.     {   // read temp
    94.         ++readState;
    95.                                 UT_I = fbm320ReadInt3(0xf6);
    96.                                 I2C_Write(fbm320_address,0xF4, 0xF4);
    97.                                 conversion_Time = P_CONVERSION_TIME_MS;
    98.     }
    99.     else
    100.     {
    101.         // read pressure
    102.                                 UP_I = fbm320ReadInt3(0xf6);
    103.                                 I2C_Write(fbm320_address,0xF4, 0x2E);
    104.                                 conversion_Time = T_CONVERSION_TIME_MS;
    105.                                 if(readState)
    106.                                 {
    107.                                                 readState = 0;
    108.                                                 Calculate(UP_I, UT_I);
    109.                                                 *pressure         = RP_I*(-10.19);
    110.                                                 *temperature = RT_I;
    111.                                                 F_Baro_Converion = 1;
    112.                                 }
    113.     }
    114. }
    115. void Coefficient(void)        //Receive Calibrate Coefficient
    116. {
    117.         uint8_t i;
    118.         uint16_t R[10];
    119.         uint16_t C0=0, C1=0, C2=0, C3=0, C6=0, C8=0, C9=0, C10=0, C11=0, C12=0;
    120.         uint32_t C4=0, C5=0, C7=0;
    121.         for(i=0; i<9; i++)
    122.                 R[i]=((uint16_t)I2C_Read(fbm320_address,0xAA + (i*2))<<8) | I2C_Read(fbm320_address,0xAB + (i*2));
    123.         R[9]=((uint16_t)I2C_Read(fbm320_address,0xA4)<<8) | I2C_Read(fbm320_address,0xF1);
    124.         if(((Formula_Select & 0xF0) == 0x10) || ((Formula_Select & 0x0F) == 0x01))
    125.         {
    126.                 C0 = R[0] >> 4;
    127.                 C1 = ((R[1] & 0xFF00) >> 5) | (R[2] & 7);
    128.                 C2 = ((R[1] & 0xFF) << 1) | (R[4] & 1);
    129.                 C3 = R[2] >> 3;
    130.                 C4 = ((uint32_t)R[3] << 2) | (R[0] & 3);
    131.                 C5 = R[4] >> 1;
    132.                 C6 = R[5] >> 3;
    133.                 C7 = ((uint32_t)R[6] << 3) | (R[5] & 7);
    134.                 C8 = R[7] >> 3;
    135.                 C9 = R[8] >> 2;
    136.                 C10 = ((R[9] & 0xFF00) >> 6) | (R[8] & 3);
    137.                 C11 = R[9] & 0xFF;
    138.                 C12 = ((R[0] & 0x0C) << 1) | (R[7] & 7);
    139.         }
    140.         else
    141.         {
    142.                 C0 = R[0] >> 4;
    143.                 C1 = ((R[1] & 0xFF00) >> 5) | (R[2] & 7);
    144.                 C2 = ((R[1] & 0xFF) << 1) | (R[4] & 1);
    145.                 C3 = R[2] >> 3;
    146.                 C4 = ((uint32_t)R[3] << 1) | (R[5] & 1);
    147.                 C5 = R[4] >> 1;
    148.                 C6 = R[5] >> 3;
    149.                 C7 = ((uint32_t)R[6] << 2) | ((R[0] >> 2) & 3);
    150.                 C8 = R[7] >> 3;
    151.                 C9 = R[8] >> 2;
    152.                 C10 = ((R[9] & 0xFF00) >> 6) | (R[8] & 3);
    153.                 C11 = R[9] & 0xFF;
    154.                 C12 = ((R[5] & 6) << 2) | (R[7] & 7);
    155.         }
    156.         C0_I = C0;
    157.         C1_I = C1;
    158.         C2_I = C2;
    159.         C3_I = C3;
    160.         C4_I = C4;
    161.         C5_I = C5;
    162.         C6_I = C6;
    163.         C7_I = C7;
    164.         C8_I = C8;
    165.         C9_I = C9;
    166.         C10_I = C10;
    167.         C11_I = C11;
    168.         C12_I = C12;
    169. }
    170. void Calculate(int32_t UP, int32_t UT)                //Calculate Real Pressure & Temperautre
    171. {
    172.         int8_t C12=0;
    173.         int16_t C0=0, C2=0, C3=0, C6=0, C8=0, C9=0, C10=0, C11=0;
    174.         int32_t C1=0, C4=0, C5=0, C7=0;
    175.         int32_t RP=0, RT=0;
    176.         int32_t DT, DT2, X01, X02, X03, X11, X12, X13, X21, X22, X23, X24, X25, X26, X31, X32, CF, PP1, PP2, PP3, PP4;
    177.         C0 = C0_I;
    178.         C1 = C1_I;
    179.         C2 = C2_I;
    180.         C3 = C3_I;
    181.         C4 = C4_I;
    182.         C5 = C5_I;
    183.         C6 = C6_I;
    184.         C7 = C7_I;
    185.         C8 = C8_I;
    186.         C9 = C9_I;
    187.         C10 = C10_I;
    188.         C11 = C11_I;
    189.         C12 = C12_I;
    190.         if(((Formula_Select & 0xF0) == 0x10) || ((Formula_Select & 0x0F) == 0x01))                        //For FBM320-02
    191.         {
    192.                 DT        =        ((UT - 8388608) >> 4) + (C0 << 4);
    193.                 X01        =        (C1 + 4459) * DT >> 1;
    194.                 X02        =        ((((C2 - 256) * DT) >> 14) * DT) >> 4;
    195.                 X03        =        (((((C3 * DT) >> 18) * DT) >> 18) * DT);
    196.                 RT        =        ((2500 << 15) - X01 - X02 - X03) >> 15;
    197.
    198.                 DT2        =        (X01 + X02 + X03) >> 12;
    199.
    200.                 X11        =        ((C5 - 4443) * DT2);
    201.                 X12        =        (((C6 * DT2) >> 16) * DT2) >> 2;
    202.                 X13        =        ((X11 + X12) >> 10) + ((C4 + 120586) << 4);
    203.
    204.                 X21        =        ((C8 + 7180) * DT2) >> 10;
    205.                 X22        =        (((C9 * DT2) >> 17) * DT2) >> 12;
    206.                 if(X22 >= X21)
    207.                         X23        =        X22 - X21;
    208.                 else
    209.                         X23        =        X21 - X22;
    210.                 X24        =        (X23 >> 11) * (C7 + 166426);
    211.                 X25        =        ((X23 & 0x7FF) * (C7 + 166426)) >> 11;
    212.                 if((X22 - X21) < 0)
    213.                         X26        =        ((0 - X24 - X25) >> 11) + C7 + 166426;
    214.                 else
    215.                         X26        =        ((X24 + X25) >> 11) + C7 + 166426;
    216.
    217.                 PP1        =        ((UP - 8388608) - X13) >> 3;
    218.                 PP2        =        (X26 >> 11) * PP1;
    219.                 PP3        =        ((X26 & 0x7FF) * PP1) >> 11;
    220.                 PP4        =        (PP2 + PP3) >> 10;
    221.
    222.                 CF        =        (2097152 + C12 * DT2) >> 3;
    223.                 X31        =        (((CF * C10) >> 17) * PP4) >> 2;
    224.                 X32        =        (((((CF * C11) >> 15) * PP4) >> 18) * PP4);
    225.                 RP        =        ((X31 + X32) >> 15) + PP4 + 99880;
    226.         }
    227.         else        //For FBM320
    228.         {
    229.                 DT        =        ((UT - 8388608) >> 4) + (C0 << 4);
    230.                 X01        =        (C1 + 4418) * DT >> 1;
    231.                 X02        =        ((((C2 - 256) * DT) >> 14) * DT) >> 4;
    232.                 X03        =        (((((C3 * DT) >> 18) * DT) >> 18) * DT);
    233.                 RT = ((2500 << 15) - X01 - X02 - X03) >> 15;
    234.
    235.                 DT2        =        (X01 + X02 + X03) >>12;
    236.
    237.                 X11        =        (C5 * DT2);
    238.                 X12        =        (((C6 * DT2) >> 16) * DT2) >> 2;
    239.                 X13        =        ((X11 + X12) >> 10) + ((C4 + 211288) << 4);
    240.
    241.                 X21        =        ((C8 + 7209) * DT2) >> 10;
    242.                 X22        =        (((C9 * DT2) >> 17) * DT2) >> 12;
    243.                 if(X22 >= X21)
    244.                         X23        =        X22 - X21;
    245.                 else
    246.                         X23        =        X21 - X22;
    247.                 X24        =        (X23 >> 11) * (C7 + 285594);
    248.                 X25        =        ((X23 & 0x7FF) * (C7 + 285594)) >> 11;
    249.                 if((X22 - X21) < 0)
    250.                         X26        =        ((0 - X24 - X25) >> 11) + C7 + 285594;
    251.                 else
    252.                         X26        =        ((X24 + X25) >> 11) + C7 + 285594;
    253.                 PP1        =        ((UP - 8388608) - X13) >> 3;
    254.                 PP2        =        (X26 >> 11) * PP1;
    255.                 PP3        =        ((X26 & 0x7FF) * PP1) >> 11;
    256.                 PP4        =        (PP2 + PP3) >> 10;
    257.
    258.                 CF        =        (2097152 + C12 * DT2) >> 3;
    259.                 X31        =        (((CF * C10) >> 17) * PP4) >> 2;
    260.                 X32        =        (((((CF * C11) >> 15) * PP4) >> 18) * PP4);
    261.                 RP = ((X31 + X32) >> 15) + PP4 + 99880;
    262.         }
    263.         RP_I = RP;
    264.         RT_I = RT;
    265. }
  • 签到天数: 12 天
     楼主| 发表于 2016-12-12 00:50:32 | 显示全部楼层
    自顶啊!!!!
  • 签到天数: 12 天
     楼主| 发表于 2016-12-12 08:47:33 | 显示全部楼层
    顶顶顶顶顶
  • 签到天数: 2992 天
    连续签到: 8 天
    发表于 2016-12-12 09:37:34 | 显示全部楼层
    谢谢分享
    签到签到
  • 签到天数: 45 天
    发表于 2016-12-12 10:20:01 | 显示全部楼层
    好东西。。。。。。。。。
    发表于 2016-12-12 10:42:43 | 显示全部楼层
    看一哈不错!!!
  • 签到天数: 32 天
    发表于 2016-12-12 12:41:10 | 显示全部楼层
    直接附工程文件就好了嘛,干嘛这么麻烦的复制粘贴
    2017-10-15 13:16
  • 签到天数: 191 天
    发表于 2016-12-12 15:15:53 | 显示全部楼层
    谢谢分享
    GMT+8, 2025-11-22 22:29 , Processed in 0.100755 second(s), 30 queries , Redis On.
