查看: 5934|回复: 1
[已解决] 做低功耗LPC824芯片进入powre_down 模式时最少能到达多少电流
发表于 2018-6-25 11:02:32 | 显示全部楼层 |阅读模式
from nxp社区群1 llyy
求助大家,做低功耗LPC824芯片进入powre_down 模式时最少能到达多少电流,我板子进入power_down 时测量整个电路电流在40UA感觉有点大,MCU外围电路多处于断电状态。LPC824资料上提示是7UA 。有谁了解这方面的?
楼主你好,看数据手册,在power down 模式下面, IDD的典型值为1.6uA-10uA。 但是有这几点需要注意下: [2] Tamb = 25 C. [3] IDD measurements were performed with all pins configured as GPIO outputs driven ...
发表于 2018-6-26 10:07:08 | 显示全部楼层
但是有这几点需要注意下:
[2] Tamb = 25 C.
[3] IDD measurements were performed with all pins configured as GPIO outputs driven LOW and pull-up resistors disabled.
[10] All oscillators and analog blocks turned off.
你查看下,看看是否这些条件满足了, 40uA的确太大了,你看看其他的模块是否都关了,还有外围的电路能不接的都不接,只测试MCU的耗电。
GMT+8, 2026-2-6 03:10 , Processed in 0.091899 second(s), 25 queries , Redis On.
