查看: 3131|回复: 1
[已解决] KEZA128 DC特性
    无聊
    2018-11-7 11:35
  • 签到天数: 5 天
    发表于 2018-9-30 17:30:37 | 显示全部楼层 |阅读模式
    Symbol Descriptions Min Typical 1 Max Unit
    — Operating voltage — 2.7 — 5.5 V
    V OH Output
    high
    voltage
    All I/O pins, except PTA2
    and PTA3, standard-drive
    strength
    5 V, I load = –5 mA V DD – 0.8 — — V
    3 V, I load = –2.5 mA V DD – 0.8 — — V
    High current drive pins,
    high-drive strength 2
    5 V, I load = –20 mA V DD – 0.8 — — V
    3 V, I load = –10 mA V DD – 0.8 — — V
    I OHT Output
    high
    current
    Max total I OH for all ports 5 V — — –100 mA
    3 V — — –60
    V OL Output
    low
    voltage
    All I/O pins, standard-drive
    strength
    5 V, I load = 5 mA — — 0.8 V
    3 V, I load = 2.5 mA — — 0.8 V
    5 V, I load =20 mA — — 0.8 V
    3 V, I load = 10 mA — — 0.8 V
    请教下 I load =20 mA和I load = –20 mA的负号代表什么?
    I/O作为输入/输出时,电流方向。
  • 签到天数: 1587 天
    发表于 2018-9-30 21:33:42 | 显示全部楼层
    I/O作为输入/输出时,电流方向。
    参与人数 1 +1 收起 理由
    NXP管管 + 1
    GMT+8, 2026-4-15 22:00 , Processed in 0.084535 second(s), 29 queries , Redis On.
