查看: 5102|回复: 0
[原创] 【LPC11U68】③+编译测试demo灯效
    昨天 15:39
  • 签到天数: 2550 天
    连续签到: 175 天
    发表于 2018-12-3 00:10:43 | 显示全部楼层 |阅读模式
           下载完“开发板资料打包.rar”后解压,里头有丰富的demo实例,有针对Keil编译环境的工程,也有针对IAR集成开发环境的工程,在这里本人搭建的是基于Keil编译的集成开发环境,进入“.\lpcopen_3_03_keil_iar_lpcxpresso_11u68\lpc11u6x\prj_xpresso11u68\keil”我们可以发现有多个Keil工程,打开进入,激活工程后才能加载库文件,在这里不再赘述有关如何设置编译环境的详细细节,只是简单的截了几张图,供大家参考。
    部分稍调后的代码:
    void SysTick_Handler(void)
            static unsigned char cnt = 0;
            static unsigned char quickCnt = 0;
            quickCnt++;
            if (quickCnt > 100) {
                    quickCnt = 0;
                    if (ledCnt == true) {
                            switch (cnt) {
                            case 0:
                                    Board_LED_Set(0, false);
                                    Board_LED_Set(1, false);
                                    Board_LED_Set(2, false);
                                    break;
                            case 1:
                                    break;
                            case 2:
                                    Board_LED_Set(2, true);
                                    break;
                            default:
                                    cnt = 0;
                                    break;
                            cnt++;
                            if (cnt > 2) {
                                    cnt = 0;
    int main(void)
            SystemCoreClockUpdate();
            Board_Init();
            Chip_GPIO_SetPinDIRInput(LPC_GPIO, BLINK_SWITCH_PORT, BLINK_SWITCH_BIT);
            Chip_GPIO_SetPinDIRInput(LPC_GPIO, CYCLE_SWITCH_PORT, CYCLE_SWITCH_BIT);
            ledCnt = true;
            /* Enable and setup SysTick Timer at a periodic rate */
            SysTick_Config(SystemCoreClock / TICKRATE_HZ1 / 10);
            /* Enable the RTC oscillator, oscillator rate can be determined by
               calling Chip_Clock_GetRTCOscRate()    */
            Chip_Clock_EnableRTCOsc();
            /* Initialize RTC driver (enables RTC clocking) */
            Chip_RTC_Init(LPC_RTC);
            /* Enable RTC as a peripheral wakeup event */
            Chip_SYSCTL_EnablePeriphWakeup(SYSCTL_WAKEUP_RTCINT);
            /* RTC reset */
            Chip_RTC_Reset(LPC_RTC);
            /* Start RTC at a count of 0 when RTC is disabled. If the RTC is enabled, you
               need to disable it before setting the initial RTC count. */
            Chip_RTC_Disable(LPC_RTC);
            Chip_RTC_SetCount(LPC_RTC, 0);
            /* Set a long alarm time so the interrupt won't trigger */
            Chip_RTC_SetAlarm(LPC_RTC, 3000);
            /* Enable RTC and high resolution timer - this can be done in a single
               call with Chip_RTC_EnableOptions(LPC_RTC, (RTC_CTRL_RTC1KHZ_EN | RTC_CTRL_RTC_EN)); */
            Chip_RTC_Enable1KHZ(LPC_RTC);
            Chip_RTC_Enable(LPC_RTC);
            /* Clear latched RTC interrupt statuses */
            Chip_RTC_ClearStatus(LPC_RTC, (RTC_CTRL_OFD | RTC_CTRL_ALARM1HZ | RTC_CTRL_WAKE1KHZ));
            /* Enable RTC interrupt */
            NVIC_EnableIRQ(RTC_IRQn);
            /* Enable RTC alarm interrupt */
            Chip_RTC_EnableWakeup(LPC_RTC, (RTC_CTRL_ALARMDPD_EN | RTC_CTRL_WAKEDPD_EN));
            while (1) {
                    rtcWake = rtcAlarm = false;
                    /* If blink switch is pressed... */
                    if ((Chip_GPIO_GetPinState(LPC_GPIO, BLINK_SWITCH_PORT, BLINK_SWITCH_BIT)) == false) {
                            /* If currently cycling... */
                            if (ledCnt != false) {
                                    /* Turn off all LEDs. */
                                    /* Set RTC to wake in one second. */
                                    Chip_RTC_SetWake(LPC_RTC, 1000);
                            /* Stop cycling... */
                            ledCnt = false;
                    /* If cycle switch is pressed... */
                    if ((Chip_GPIO_GetPinState(LPC_GPIO, CYCLE_SWITCH_PORT, CYCLE_SWITCH_BIT)) == false) {
                            /* Start cycling... */
                            ledCnt = true;
                    __WFI();
            return 0;
    小测视频.zip
    622.2 KB, 下载次数: 0, 下载积分: 威望 1
    暂时没有注册优酷账号,将就以附件的形式上传了
    GMT+8, 2025-10-28 17:27 , Processed in 0.078650 second(s), 20 queries , MemCache On.
