12
返回列表 发新帖
楼主: prayer_hong
[S32] 用JLINK+Freemaster调试S32K144,每次打开都需要填芯片型号
  • 签到天数: 47 天
    发表于 2019-1-21 16:42:48 | 显示全部楼层
    prayer_hong 发表于 2019-1-21 11:06
    SEGGER J-Link GDB Server V6.16f Command Line Version
    JLinkARM.dll V6.16f (DLL compiled Jul  3 201 ...
    仅供参考
    SEGGER J-Link GDB Server V6.22e Command Line Version
    JLinkARM.dll V6.22e (DLL compiled Jan  8 2018 11:44:25)
    Command line: -if swd -device S32K144 -endian little -speed 1000 -port 2331 -swoport 2332 -telnetport 2333 -vd -ir -localhostonly 1 -singlerun -strict -timeout 0 -nogui
    -----GDB Server start settings-----
    GDBInit file:                  none
    GDB Server Listening port:     2331
    SWO raw output listening port: 2332
    Terminal I/O port:             2333
    Accept remote connection:      localhost only
    Generate logfile:              off
    Verify download:               on
    Init regs on start:            on
    Silent mode:                   off
    Single run mode:               on
    Target connection timeout:     0 ms
    ------J-Link related settings------
    J-Link Host interface:         USB
    J-Link script:                 none
    J-Link settings file:          none
    ------Target related settings------
    Target device:                 S32K144
    Target interface:              SWD
    Target interface speed:        1000kHz
    Target endian:                 little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link ARM V8 compiled Nov 28 2014 13:44:46
    Hardware: V8.00
    S/N: 12345678
    Feature(s): RDI,FlashDL,FlashBP,JFlash,GDBFull
    Checking target voltage...
    Target voltage: 5.08 V
    Listening on TCP/IP port 2331
    Connecting to target...Connected to target
    Waiting for GDB connection...Connected to 127.0.0.1
    Reading all registers
    Read 4 bytes @ address 0x00000000 (Data = 0x20007000)
    Received monitor command: speed 1000
    Target interface speed set to 1000 kHz
    Received monitor command: clrbp
    Received monitor command: reset
    Resetting target
    Received monitor command: halt
    Halting target CPU...
    ...Target halted (PC = 0x00000410)
    Received monitor command: regs
    R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
    R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
    R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
    R12= 00000000, R13= 20007000, MSP= 20007000, PSP= 00000000
    R14(LR) = FFFFFFFF, R15(PC) = 00000410
    XPSR 01000000, APSR 00000000, EPSR 01000000, IPSR 00000000
    CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
    Read 4 bytes @ address 0x00000410 (Data = 0x490BB672)
    Target interface speed set to 100 kHz
    Received monitor command: flash breakpoints 1
    Flash breakpoints enabled
    Received monitor command: semihosting enable
    Semi-hosting enabled (Handle on BKPT)
    Received monitor command: semihosting IOClient 1
    Semihosting I/O set to TELNET Client
    Downloading 1024 bytes @ address 0x00000000 - Verified OK
    Downloading 16 bytes @ address 0x00000400 - Verified OK
    Downloading 4096 bytes @ address 0x00000410 - Verified OK
    Downloading 4096 bytes @ address 0x00001410 - Verified OK
    Downloading 4096 bytes @ address 0x00002410 - Verified OK
    Downloading 4096 bytes @ address 0x00003410 - Verified OK
    Downloading 4096 bytes @ address 0x00004410 - Verified OK
    Downloading 1580 bytes @ address 0x00005410 - Verified OK
    Downloading 2504 bytes @ address 0x00005A3C - Verified OK
    Read 2 bytes @ address 0x00000608 (Data = 0xF7FF)
    Comparing flash   [....................] Done.
    Verifying flash   [....................] Done.
    Resetting target
    Setting breakpoint @ address 0x00000608, Size = 2, BPHandle = 0x0001
    Starting target CPU...
    ...Breakpoint reached @ address 0x00000608
    Read 4 bytes @ address 0x00000608 (Data = 0xFF98F7FF)
    Removing breakpoint @ address 0x00000608, Size = 2
    Read 1 bytes @ address 0x200001DC (Data = 0x00)
    Reading 64 bytes @ address 0x00000600
     楼主| 发表于 2019-1-21 18:30:11 | 显示全部楼层
    weekbbg 发表于 2019-1-21 16:42
    仅供参考
    你这个不是用Freemaster吧。Freemaster没有传递芯片型号的位置
  • 签到天数: 47 天
    发表于 2019-1-21 18:51:05 | 显示全部楼层
    哦哦,sorry,没注意题目,有空我看下
    GMT+8, 2026-4-20 01:01 , Processed in 0.086871 second(s), 22 queries , Redis On.
