查看: 5548|回复: 1
[其他] 为啥ADC读出来的值一直是4095
发表于 2018-7-30 17:55:01 | 显示全部楼层 |阅读模式
芯片是 lpc54113, 为啥ADC读出来的值一直是4095,折腾了很久,望知道的人不吝赐教,谢谢
代码如下:
int main(void) {
        adc_result_info_t adcResultInfoStruct;
          /* Init board hardware. */
    BOARD_InitBootPins();
    BOARD_InitBootClocks();
          /* Init FSL debug console. */
        BOARD_InitDebugConsole();
    //printf("Hello World\n");
    /* Enable the power and clock for ADC. */
    ADC_ClockPower_Configuration();
    PRINTF("ADC basic example.\r\n");
    CLOCK_EnableClock(kCLOCK_Gpio1);
    /* Calibration after power up. */
    if (ADC_DoSelfCalibration(DEMO_ADC_BASE))
        PRINTF("ADC_DoSelfCalibration() Done.\r\n");
    else
        PRINTF("ADC_DoSelfCalibration() Failed.\r\n");
    /* Configure the converter and work mode. */
    ADC_Configuration();
    PRINTF("Configuration Done.\r\n");
    while (1)
        /* Get the input from terminal and trigger the converter by software. */
        //GETCHAR();
        ADC_DoSoftwareTriggerConvSeqA(DEMO_ADC_BASE);
        /* Wait for the converter to be done. */
        while (!ADC_GetChannelConversionResult(DEMO_ADC_BASE, DEMO_ADC_SAMPLE_CHANNEL_NUMBER, &adcResultInfoStruct))
        PRINTF("adcResultInfoStruct.result        = %d\r\n", adcResultInfoStruct.result);
        PRINTF("adcResultInfoStruct.channelNumber = %d\r\n", adcResultInfoStruct.channelNumber);
        PRINTF("adcResultInfoStruct.overrunFlag   = %d\r\n", adcResultInfoStruct.overrunFlag ? 1U : 0U);
        PRINTF("\r\n");
    return 0 ;
谢谢
看你使用的官方的SDK代码,你手上有LPC54114的板子吗?你可以按照readme的提示进行测试,我是怀疑你的引脚接错了或者配置错了。
发表于 2018-7-31 09:48:53 | 显示全部楼层
GMT+8, 2025-10-25 13:26 , Processed in 0.081261 second(s), 23 queries , MemCache On.
